Truck hit on right side, acts like in limp mode. Truck took to dealer, dealer found no throttle response, erratic turbo boost, and no power. Both wiring harness replaced, turbo checked and new actuator replaced. Intake heater gaskets replaced and pressurized test done.Computer reprogrammed. No progress nor ideas on a fix! Any ideas?
right side front , right side rear? middle? no lights or codes?
just acts like it's in limp mode? brake stuck? tranny messed up?
No codes, no lights, hit on right front, wheel and bumper, no transmission issues or brakes! Throttles will go to floor, take a long time to get to speed, turbo boost is up and down continuously! Ran fuel test, injector test, rail psi, ect.
Is the 2015 'drive-by-wire'?? If so, could that module be damaged??
Just a WAG
