Very good info. Definitely interested as I've heard that the 13+ trucks can be a nightmare with the BCM playing ball with any kind of trans swap. Also pictures would be great.
I honestly thought it was going to be way worse than it was. A lot of it im sure depends on your tuning as well. Aside from running the wire for the neutral safety, it was all nuts and bolts, just like replacing a clutch.Very good info. Definitely interested as I've heard that the 13+ trucks can be a nightmare with the BCM playing ball with any kind of trans swap. Also pictures would be great.
Honestly, trading in would be the easier route to go. But as far as cost goes, I guess depending on where one might stand as far as what is owed/done to their Truck, the swap was cheap. I bought my truck 2 years ago with 10k miles for 41k which was very cheap especially at that time. If I were just tuned then I would maybe consider a trade vs. Swap. I used mostly factory mopar parts, 1500 on a valair dual disk, and 3k on a g56. Said and done, including fluid for the g56, I'm about 5k invested.It seems that the 4Lo issue is a big one - interested to hear how yours works. I regret not buying the G56, too, but I think I would trade in rather than convert.
No problem at all. I'm putting a list together right now for you.Very cool. Might be a good sticky with the part numbers listed?
Very good point. I honestly didn't even consider that yet. But you're right, I've seen them sell for anywhere between 1500-2500.Your cost should include whatever you can recover from selling the 68RFE. Should be worth $2k? Makes the numbers even more appealing....
Thank you my man! My buddy owns a junkyard up in long island and he had one from a rolled over 2013. That's about all that was salvageable from that truck as far as parts I needed.Hell ya man. Glad you got the project done. Where did you source the g56 from?
I am about to do the same, waiting on my file from the guys at HPP currently, just wondering if you have any advice on the wiring for the reverse lights and clutch wiring? as far as colors of the wies in the loom that need to be run or grounded? I am doing mine with a triple disc, should make things really interesting.Another update for everyone. Now have about 700 miles since my swap. All is working as it should. The clutch seems to be breaking in well. It's become a little less noisy.
My 68rfe (with toasted overdrives) , converter, flex plate, mount, and bell housing adapter are now all sold. Now that's 2500 back in my pocket. Brings my swap from 5k in the hole back to 2500 in the hole. But now as it's time for some tires, it doesn't hurt so bad for another set of 35's
I honestly never messed with the reverse lights. I just got the harness that's supposed to go from the reverse sensor back. Once work slows down I'll get back into that. Only wire I had to mess with was pin 4 on the 68rfe connector. Yellow wire with blue tracer. It either needs to be grounded or wired to a clutch safety switch like mine is. Otherwise truck will not crankI am about to do the same, waiting on my file from the guys at HPP currently, just wondering if you have any advice on the wiring for the reverse lights and clutch wiring? as far as colors of the wies in the loom that need to be run or grounded? I am doing mine with a triple disc, should make things really interesting.
Cruise works, and high idle works. In order to turn high idle on, parking break has to be engaged. I did no wiring for that, I think that was something that was taken care of with tuning.Is cruise control working for you after the swap or is that asking for too much?
Will be starting my swap tomorrow afternoon and hopefully have it all wrapped up and driving again by tomorrow night or saturday morning sometime, my truck was the generic 68rfe flip seat, got a complet package deal with the shorter back flip seat, bell housing adapter, valair triple, new hydros, trans, and also scored an aluminum 1 piece out of the deal. from what i have read and researched, using the tunes the HPP sent me (manual tune file), everything i have seen and heard all works just like a 56 equipped truck, high idle, cruise, and all. All i really have to focus on is the reverse light wiring which shouldn't be too bad and then the clutch swithc/starter safety wiring through pin #4 in the 68rfe harness. I plan to swap to a BW 4447 or 4446 whichever is the manual t case later down the road as well just to do away with the electrical crap that seems to sneak up on these trucks as they age. Soon after that i am doing the Spyntec free spin hubs and swapping a non CAD passenger side axle shaft in and will be working on a way to keep the service 4wd lights off other than zip tying the module somewhere. Almost done with my 10-12 intercooler conversion as well, that one is going much smoother than anticipated, using a damaged mishimoto IC made the repairs, and made new upper mounts, other than that the whole swap over was really simple, i will get some pics and more information up for those that may be interested in any of it.Did your truck have a full length floor console previously? I was interested in doing this swap but the center console swap worries me.
Anyhow, I appreciate the write-up, look forward to swapping my 68rfe when it blows up.
