He said that in his first post, but that they can also easily be swapped.Your 2011 will have the HO badge on the tailgate if indeed it has that motor well, unless someone has debadged it. My late production 2011 has the HO with said badge.
Put your VIN number in this site, it will give you your Build Sheet.Good day people!
I have a 2011 dodge ram 2500 slt with 6.7 Cummins 68RFE trans with tow package.
I'm trying to figure out if it has the high output or standard output. It has a badge on the tailgate that says high output put I'm the second owner so who knows if that's the original tailgate. I've looked on this forum to but no solid answers.
I've called a bunch of dealerships with vin number and they can't seam to give me a solid answer some say it is and some say its not. I even called Cummins they couldn't tell me either.
So is there another way to find out which Cummins my truck has?
Thanks all!
Good day people!
Thanks all!
That's some good info there thank you much appreciated!!Check out this information, it says 2011.5 for the H.O. within 800 ft. lb. and the 68RFE.
Go online and pull up your window sticker. That will tell you everything you need to know.Good day people!
Thanks all!
