***UPDATE 1 JUL 2013 - Finally have new pics up
Not sure if this has been posted here yet but thought I'd share. Picked up this little trick from the Tundra folks Mod Weekend - TundraTalk.net - Toyota Tundra Discussion Forum and found it very useful in my old truck. Pulled the seats out of the Dodge today and what'dya know... same set up. So here's the deal, you can convert the back seats to allow them to fold down giving access behind them for additional storage (see pic below).
Very easy, you'll need:
1) 18 mm socket and something to turn it with
2) hacksaw, dremel or other metal cutting device
I didn't have my camera while doing this so all my pictures are after the job was done.
To do this mod, remove the rear seats by first removing the 8, 18 mm bolts holding them in place. Mine had some kind of thread lock from the factory. The rear seats are two pieces making it easy to maneuver them around. Next take your cutting implement and remove the metal material BELOW the white plastic. I don't have a pic before cutting but I think its pretty self-explanatory. I plan to clean these edges up but it works fine as is.
This is how much I cut off.
Then reinstall the seat. Thats it. To get the seat back to tilt forward you move the lower seat to ~45 degree angle and pull the seat forward. At full down or full up position the seat back will lock as usual. Here are the seat backs in the down position
