Hey guys, I'm new here and have a question some of you might know the answer to.
If I bought a 2010 Ram 3500 and installed a Kore suspension system would it void the warranty on the truck?
Depends on your dealer and DODGE. If they suspect non-oem parts caused the issue they will refuse to honor the warranty. They can even do it for something as small as adding 33s, if the want. "You burned up the rear end as the bigger rubber retarded the gear ratios..." Also, a dealer can go out of business at any time or a new service manager who plays by the rules could be appointed.
Magnusson-moss act is worth googling, though good luck beating their lawyers if you're modded.
It happens, and with a full-on lift kit they have a point. Pay to play is the term, if you can afford to pay out of pocket then lift it. If you can't, don't.
