ok i am looking to upgrade in injectors and would like to run some 200hp injectors as i am getting bored with the 125hp ones i have now. would it work to run 200 hp injectors with my super 40 turbo. i have seen several guys that in there signiture on here says they have a hx 40 turbo and they run 200s.
what kinda luck do you guys have with this? what are your egts???
or would it be best to upgrade to a super b special or like a 64/71/12 or something of that size?
I am planning to run 250s with a hy35 for a bit before the weather warms up and I get the new turbo in .....
but your plan should be to get a bigger turbo down the road like me
I think you would be better off getting a super B special or something similar to that. I have 150's with an HX40 and i think it runs to hot.(1600 at WOT) But then again they are jammer 5's, so a bigger injector with a better spray pattern than the jammers might not be that bad. You would deffinetly gain more if you had a bigger better turbo like the special. whos injectors are you going with?
I run 200's with my Cat/BW and it will peg the 1500F pyro in less than 10 seconds WOT w/Comp on 5x5 and 42psi boost.
I believe 200's really need twin turbos.
if u up grade injectors, how much u want for your old ones? what brand are they? they run good?
Well I have jammer 4s and ya I can hit 1500 deg. Egt s
