1 - 3 of 3 Posts
Hi from the noob,
Just inherited a 6.7 that has been sitting for 2 years. what should i do to carefully get it running again?
I assume draining fuel and cleaning lines and filters along with oil would be the start. Anything else?
Thanks
Jay
These engines are not made of glass. New fuel filter, or drain the existing and check for water.
Fresh fuel, fully charged batteries and oil showing on dipstick. Giver a try. If everything runs good, treat it with an oil change.
I had mine sitting 5 years, put in new batteries took off return line from fass drained fuel let it run for a bit. Now I know it's working fine I will change oil and fuel filters.
1 - 3 of 3 Posts
