I’m looking to replace s the entire headlight assembly, not just the bulbs, with some brighter lights and preferably LED. Are there lights that I can buy that just plug and play into the existing headlight wiring harness? Any recommendations?
Nothing is "plug n play" with these trucks unless you stick with OEM, halogen bulbs.Yes I saw that but was looking for suggestions on what would be good quality. They range from 100$ To 1000$ per set. Also if they are all plug and play direct replacements
Re-read my post.What is the reason that it messes with the computer? What problems exactly does it cause? I found a few lights that say they are a direct fit and mount to the existing wiring harness so I’m interested to hear more
6 pages of troubles it seemed... And they still don't work properly?... and they work awesome however they are not 100% plug & play. Light out put is great, not perfect but it is significantly better than the halogens.
I encourage you to re-read my first reply and then Google search on why dropping LED or HID bulbs into a stock halogen reflector housing is not a good idea...mostly for OTHERS safety. There are forums out there dedicated to lighting and it only takes a few minutes to dig up those threads.![]()
H13 40W 7000LM Plug and Play LED Headlight Kit (PAIR)
Ready to shop H13 40W 7000LM plug & play LED headlight kit? Enjoy bright, crisp 6000K white color. Order now; get 2-year warranty, discount prices & free shipping.undergroundlighting.com
Is this legit?
Flickering? Not sure what you're talking about there. No lights that are properly working should flicker.Ok I was under the impression that the main safety concern for oncoming traffic was the flickering caused by some lights. The ones I posted claim they do not flicker or cause engine lights which is why I was asking about them. They’ve been “engineered” to fix those problems supposedly
