Just got me Superlift 4" standard lift installed and it bangs like hell in the front on not very big bumps. I already cut the bumpstops down 1" but it still hits perty hard. Not sure if I'm hitting the bump stops still.
I have the standard 4" lift with Bilstens and the duel front steering stabilizer. Im running 35" BFG Km2 on moto metal 17x8 wheels
Anyone have a similar issue with a Superlift.
I also had to do a lot of trimming in the front fenders to get the tires to clear.
sounds like youve got something f&^ked up. you should have to trim anything with that lift and tire size. wrong backspacing?
looks like on my truck, the track bar drop bracket is hitting on the front diff.
Going back to the guy who installed and will try to fix problem
After looking on Superlift's 6" install instructions, it seems that I had recieced 6" link arms. They give the center measurments in the instructions. I had no part# stamped on them but they are easy to figure out. This all makes sense why I had to trim and probably why I hit on the front diff. with the drop bracket.
Will be giving Superlift a call in the morning and going to my mechanic to make some small mods to clear the diff. I hope
Good luck!
