1 - 11 of 11 Posts
Hello my name is steve i have a question to ask. I have a 2005 Dodge 2500 4x4 cummins. I want to lift my truck but im stuck in what should i do! I have a 4 inch leveling blocks for the rear now for the front should i go 4" too? Also, what shocks do you recommend? Help pls thanks!
2.5" level spacer in front, leave rear stock, get some bilstein 5100's, slap some 35's on the stock rims...problem solved.
3" spacer front, stock rear, 35's. im actually gonna buy 37's when i need tires to fill the wheel wells some more.
if your looking for a big 4x4 look...any 6" kit w/37s' will do ya.
Go with a full coil for leveling!
Carli and Thuren will both level out you're truck give you better over all ride quality. I really do not like spacers as I feel they are not as safe as a coil that is completely seated in the upper coil bucket.
here's an 08 stock before and after Carli Starter System on 35's for reference
I would never recommend a rough country or any other mass producer off the shelf super rigid lift company.
Carli or Thuren!
1 - 11 of 11 Posts
