1 - 4 of 4 Posts
Hey guys need some help. My dad and I just replaced his injectors on his truck. But now when you start, it will just idle for about 5 seconds and then dies. So I was looking on the internet and got some ideas and they were clean all the electrical connections, drain the fuel filter may have water and take off all the battery terminals and let it set for about 15-20 minutes. Any other ideas or ways to fix or find the problem.
How about checking for codes?
Double check your torque on all connector tubes and fuel line fittings, I had a similar situation in the past and it turned out to be a loose fitting
1 - 4 of 4 Posts
