1 - 14 of 14 Posts
Hey guys I've got a 2004 2500 with 98,xxx miles. When I put it into gear it won't do anything like won't rev up when I press on the gas pedal just idles. I cut the engine off came back in 5 mins started it up and acted perfectly fine. Help please!!!!
did you pull codes?
also how cold out is it?(fuel gelled?)
I had just gotten out of it. I had just drove it about 100 miles round trip. So Im thinkin the fuel was ok. And I mean 5 mins later it acted fine. And how do I pull the codes?
I just pulled the codes. Only one that showed up was p0234.
code P0234 = Turbo Boost Limit Exceeded
that should not have anything to do with your rig not moving
Sounds like an APPS going out.
Some of these trucks use different system for the throttle input, and I have no idea which use what system.
My 03 auto has its APPS on the left side front of the engine. My neighbors 04 w/manual trans does not have anythng located in that same location.
When they start to crap out they tend to randomly give a "dead pedal"/no response to skinny pedal input, then all of a sudden fine again.
I really appreciate the comments. I will look into that APPS sensor and see if that fixes it. Thanks again guys!
I had that happen 2 times, then found out that my quadzilla wiring harness was causing the issue. Removed quad, got a smarty tuner and hasn't happened again. Thought i would mention this if you have a quad. Fill out your sig. So we can see if your stock or what is done to your truck.
Discussion Starter · #10 ·
I appreciate man, and I have a smart s06 on it. And I just did the signature thing.
It's acted fine today.
check connections to ecm c1 connector , iat sensor and FCA connector
bad connections can cause p0234 code, iat shares signal/power with turbo boost pressure sensor and also FCA circuit ie fuel pump driver , fuel rail pressure return signal.
Were is the iat sensor and fca circuit located and which one is the c1 connector
thanks Gary
if you do decide to get a apps get timbo apps half the price of oem and for the more indistrial engines. great guy he helped me install mine. 165$
1 - 14 of 14 Posts
