They all have overdrive.
U r right MCummings but i also have to correct u on the early 03-04.5. the 47re only came in the non HO trucks. If u have and HO motor 03-04.5 you do have the 48re.
Sounds good but i've got an 03 so motor with a 48re. Dodge did alot of different things with these trucks and no matter how hard we try to figure it out there will always be something different.U r right MCummings but i also have to correct u on the early 03-04.5. the 47re only came in the non HO trucks. If u have and HO motor 03-04.5 you do have the 48re.
Since Jan 91 all diesels in these trucks have had an OD, same ratio.Since 1994 All Dodge Diesels Have had OverDrives, manual or automatic.
2004.5 is the cutoff for the 47RE auto, and the 48RE Auto. The 48re is a little stronger/durable. It is found in '04.5 until '07.4 Diesel/Autos.
Merrick
