1 - 13 of 13 Posts
Recently my plastic tanked radiator started dripping from the bottom corner right by the drain pet. It appears to be coming from where the plastic tank is clamped to the metal core. It is not very bad at all yet but now definitely on the to-do list before summer heat.
Wondering what is the best affordable improvement replacement? Is there a newer year factory unit with improved cooling that will bolt in?
Right now finances dictate shopping used OEM preferred instead of cheap chinese, just looking for the best one to look for.
I vaguely recall discussion of maybe a 2007 being a good upgrade for older rigs but can't find it again, and won't trust my vague memory.
Searched and read some threads that mostly talked about 3 row vs 2 row vs expensive aftermarket but didn't find anything about improvements in OEM from different year gen 3 rigs.
Thanks!
I installed one from O’Reilly. It works just fine for me.
However I also installed a thermostat from O’Reilly and it was junk. Had to replace the O’Reilly thermostat with one from NAPA and replaced the radiator cap with OEM. Now I’m good on cooling.
I recently put an all aluminum radiator in my 06. Got it from ebay, it looks and performs very nice. the only thing is it take a smaller radiator cap! It looks like a mishomoto knock off.
TECH SPECIALIST
My OEM radiator had a nasty end tank leak, I took a pair of vice grips to all of the crimps on each tank and tossed it back in there. The intent was to have it last long enough for me to go source a better radiator than what I pulled out (BTR junk) and be off & running again leak free.
2+ years later, still no leaks from it and I have not swapped it out.
All Aluminum would be the way to go.
I broke the factory plastic drain when I did my flush. LOL POS.
I was lucky and found a Mishimoto someone bought and then sold his truck. I do really like and for 400.00 not to Bad.
Dave, I think you got your answer in post #4. Steve's always good for an effective economical solution.....
Thank you Steve. I've considered that a couple times over the years and just ended up replacing a radiator. Valuable info like THIS is why forums like this are great!
Yaeh NEVER use that dinkey pet gizmo for that very reason.
Just pull the lower hose ( carefully) and let nature take its course.
Reactions: utahtrapper
Discussion Starter #9
Hello Steve and everyone,
I was actually wondering if I could clamp it again. Its not much of a leak, about 6" of damp concrete overnight, but can't tell when driving under full pressure. Didn't want to go crimping on the 14 yr old plastic POS unless someone had gone there before. Definitely didn't want to risk making it worse and have absolute replacement come even sooner.
I have built and worked on a lot of classic muscle cars in the distant past, always a challenge to keep those old gassers cool, especially in summer heat & in town traffic.
4 core brass was always the ticket, over 400 cid and 400+HP a 4 core would barely do it but it was the best we had. HD thermo clutch fan out of a 500cid Cadillac helped a lot.
Thanks guys, Dave
TECH SPECIALIST
Thanks guys, Dave
I clamped on mine 1x with zero issues in the time after... you can certainly try it... just set the vice grip so it does not over crimp it. Read up/look up web info on it or videos...
TECH SPECIALIST
Yes, it's called a lifetime guaranteed aluminum radiator from Mishimoto and Kool thermostat.
that would require a new shroud for my fans if the core size is different... would be a good excuse to go to rev b of the shroud.
I believe it is a factory defect. Cracks at the upper driver side mounting bracket. Tried JB weld, but did not last long. When the plastic expands it opens back up. I replaced mine with the same, but after market. Should of went aluminum. Took 5 hours to change, next time i'll do it in 4.
1 - 13 of 13 Posts
