Just finished giving the truck its weekly look over. Power steering fluid is down past the add mark, local mechanic had a look at it and said its leaking a bit around the shaft seal, recommended to use Lucas power steering stop leak, done. Said this should take care of the leak for a while until I decide to replace the pump. Who makes a good pump other than OEM. Any thoughts would be much appreciated.
