1 - 2 of 2 Posts
Overview:
The ICON Vehicle Dynamics 2003 – 2012 Dodge Ram 2500 / 3500 4WD Coilover provides an excellent ride on and offroad while allowing the vehicle to be adjusted from 3-5 inches of lift. Often times the addition of bumpers, winches, and other equipment such as snow plows causes the front end of these trucks to sag. With the ICON Ram 2500/3500 coilover, this can be compensated for by a quick adjustment of the shock. These are not simply a race-style shock that has been modified to fit this application, but rather a shock that was designed from the ground up with on and offroad performance in mind. ICON tested and tuned the Dodge Ram coilovers to ensure stability and drivability over a wide range of terrains. We include a remote reservoir to facilitate proper heat dissipation, and also offer our CDC (Compression Damping Control) Valve option to allow further adjustability.
Key Features:
• 6061 Aircraft grade aluminum CNC machined components
• Corrosive resistant CAD plated shock body
• 7/8" polished nitro steel shaft
• FK rod end bearings for extended longevity and minimal deflection
• Remote reservoir for excellent heat dissipation
• Adjustable ride height 3-5" lift height
Tech Info:
Requires 212510 - ICON Fabricated shock tower upper mounts for use
Proper length bump stops are required
Sold as a pair
Overview
The ICON Fabricated Shock Tower for the Ram 2500 / 3500 4x4 trucks was purpose built to increase durability over the factory stamped steel bracket. When the heavy duty Ram is used in extreme offroad or abusive situations there is concern as to "if" the factory mount is strong enough to take the punishment. Installing the ICON Fabricated Shock Tower not only gains strength from the mount itself, it also allows for an eyelet shock rather than a stem top shock adding even more strength for a bullet proof set up.
Another use for the ICON Fabricated Shock Tower is to install the new ICON 3-5" lift coilover conversion system. The increased mounting height allows us to mount a coilover shock in the factory position to get sufficient travel and lift heights.
Key Features:
• Constructed with laser cut 3/16" & 1/4" steel
• Precision Welded
• Stud ring with Gr. 10.9 mounting studs
• Bolt on with no fabrication required
Tech Info:
Requires proper length shock or coilover for use
Fits 1994 - 2012 models Dodge Ram 2500 / 3500 4x4 trucks
1 - 2 of 2 Posts
