1 - 2 of 2 Posts
I have found a 2002 extended cab 2500 4x4 that I am interested in buying. It has been a long time since I have owned a 2nd GEN and the last one was a '99. In general is there anything that I should look for on this truck that could cause me undue problems and stress.
Mopar1973Man.Com
Check for error code...
OBD II Error Codes
Check the fuel pressure and/or volume...
Lift Pump Diagnostics
The weak link on these truck is the lift pump. If the pressure falls below 10 PSI at WOT then the VP44 takes a beating... Error codes will tell if the VP44 has damage or any other system and the pressure test will tell if the lift pump is dieing on you...:w:
1 - 2 of 2 Posts
