I replaced the lift pump and changed the fuel filter. Now my truck won’t turn over! I can hear the pump engaging, it’ll crank but no start! Really don’t know where to go next!
If it cranks then its turning over thats the same thing… you have to crack a couple injector lines until the fuel bubbles out a bit then tighten them and start the truck it may run rough for a few seconds as the rest push the air out
Ok everyone, sorry. When I turn the key, it acts like it wants to start, I can hear the pump running but it seems that the fuel runs back into the tank!? It does not start.
It sounds like you need to bleed the air out of your fuel system.
Bleeding it isn't hard, make sure the batteries are fully charged.
Crack 1,3, and 4 and crank the starter for around 10 seconds.
Let it sit for 20 seconds and crank for 10. Repeat this while watching the lines. Once you get good fuel streams close the ones streaming and keep going until it starts.
Let it run while you close the remaining lines even if it's running rough. It will smooth out as the lines are closed.
That's how I've done it after fuel filter changes, don't think I forgot anything.
How any times did you crank it over for 10 seconds with the 3 fittings open? And yes if it is not bleeding the VP is likely bad caused by the original failed lift pump.
I have a hot wire to my pump for filter changes.
It eliminates a mess.
I then run it until air quits coming out of the filter fiting on top.
Then with three injectors cracked open, I crank it over until fuel comes out.( NEVER run a starter for more than 30 seconds)
It will not take even that long for it to start. Then snug up the injectors and fire her up, then tighten them up.
I always do the filter with the engine hot.
If not have her plugged in for a couple of hours.
I had the same issue once. I replaced my fuel filter and lift pump I’m a dummy and routed my fuel lines to existing lines and was pulling fuel through the dead pump that was on the sending unit in the tank. Once routed directly to tank, I got pressure. Maybe give a look at pump in the tank?
The pump I m referring to is in the tank attached to the sending unit that reads your fuel level. My truck did have a lift pump and the unit in the tank
In tankd was a Mopar mod to get failed pumps off the vibrating block. One pump(either way) should never be pumping through another. Alwaysremove/bypass any unused pump to eliminate restriction. When the Moparmod or another good one is done a bypass block is included to connect the lines at the block.
Related Threads
Cummins Diesel Forum
8.8M posts
379.7K members
Since 2005
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
