1 - 3 of 3 Posts
I dont know anything about trucks so Im not sure how informative this will be, but my boyfriend is having trouble with his truck and maybe you have answers! He is losing power when he accelerates and the truck makes a sort of gurgling-roaring sound. He has replaced the fuel filter/fuel pump, MAP sensor, fuses are good. No trouble starting it. He is looking for our code reader thing to see what codes it has. Has anyone had a similar problem and figured out how to solve it, without spending an arm and a leg?
If you/he fills out your signature that will be a good start. Include everything about the truck including all mods. Start using the search bar above and see if you can narrow it down a little. Can’t emphasize enough to make sure all wiring and GROUNDING Systems are perfect. Once again search for it. Get back with the codes.
1 - 3 of 3 Posts
