1 - 11 of 11 Posts
What is my rpm gonna be at 75 mph? and any difference i will notice with my truck?
@ 75mph im turning about 2050rpms....but that's w/ 4.10's
Reactions: chris.roan
rpm= MPH x total gear ratio x 336
tire diameter
rpm= 75 x 3.73 x .72 (OD) x 336
35
rpm= 1933.632
May be slightly higher as the tire won't actually measure a true 35 inches. Hope this helps.
so its acualy gonna be great cause now with stock rims and tires i feel like im almost in the red zone! This will make a much quiet ride.
It should help some definately
I'm turning 2050rpm with 35's at 70. but I don't know what gears I have
I'm running around 2100 rpm's at 75 with 3.73's
Some one turned me onto this thread when I was deciding what gears to go with/with 37's :thumbsup:
you'll need to imput some info:
if not sure on some info, just measure your tire height, and rpm at a certain speed and you should be able to play with it and fig your gear ratio. info also depends man. or auto. The link will explain.. Good luck :party018:
Engine RPM Calculator
and i think stock auto vs after market as well...
To measure your true tire hieght go to your tire brand website. Not all 35s are 35s and using a tape measure doesnt do the diameter justice. I running firestone dest Mts. 315 70r 17s .. my tire size is 34.7 BFGs are 34.5 ect:confused013: ect
actually the math on the 325 60 20 is basically 35.4''
1 - 11 of 11 Posts
