On my 03 2500 diesel if i put a 2" leveling kit on could i run 35's with no issues?? thanks!
I have a 2.5 inch leveling kit from Hell Bent Steel and run 35s with no problem or rubbing. My brother has the same set up and rubs a little at full turn due to different wheel offset.
sorry i meant 2.5 ok perfect!!
Gone Fishin'
i also have the HBS 2.5" leveling kit and run 35" yokohamas. they do rub on the lower control arms when the wheels are turned all the way but its no big deal.
ya they will fit fine! i ran that with 17'' rim and 35'' tires cleared no problem!
every truck is a little different i ran 35s with no leveling kit just fine with minor control arm rub at full lock now with a 2" leveling kit have no rub at all...when my 35s wear out im gonna stuff 37s under it
