1 - 2 of 2 Posts
ive been seeing a lot of people on here say something about 2 stroke oil.
when and how much and how how often do you do this.
and which is better doing the 2 stroke thing or adding aimsoil diesel fuel additive every fill up? :confused013:
You will get many differant opinions. :confused013:
When ULSD hit the market, I started using 2 cycle oil at the rate of 2/3 oz per gallon of fuel. My concern was to make sure there was enough lubrication in the fuel for the injectors and CP3. Removing the sulphur also removes the lubricants and they must be added back. This is normally done after the fuel travels through the pipelines to the distrubation centers. I just don't trust that it is mixed well or enough lub is added.
Added filtration and water seperation can be just as important, if not more so.
1 - 2 of 2 Posts
