07 2500 with a goerend built in 2011 with 120,000 miles on it now. Btw I do drive it a little hard. The past 2 weeks it seem like a little slow to Shift Maybe it was just me. I was slowing down at a red light got to 5-8 mph. I think it Went to 1st but I heard something and felt something. Like turns green hit the gas little bit some is not right its slipping. I was on my way home 5 miles from home only had to stop 2 times. Yes it's definitely slipping now. I'm draining it right now has a little color to it does not smell burnt. What do I do I'm guessing this a full rebuild probably? It's slipping in drive,2 and 1. It's not slipping in reverse.
OK the pan is off. Filter was a little loose. The 3.8 lever I can Pinkie pull 1/2"and it's easily?
put new filter(35 in/lbs) fluid, adjust bands
try it , 120k hard miles could be worn clutch(rear) issue.
It sounds like you're losing the forward clutch. The band is not used in first gear, and 1/2" at the lever is a little loose, but not enough to prevent it from working. It's never a bad idea to adjust your bands and change your filter. I'm just not sure it's going to fix anything for you.
Yeah figured you are right still slipping. Question is what broke that made it slip?
Could just be worn out, what are pressures?
If you were sucking air into trans(loose filter) could cause a lot of issues.
