I am looking at a 1999 Dodge 2500. There are two problems with it. 1 overdrive does not work on it. (how much would it cost to get that fixed?) 2 the fuel injector pump needs rebuilt, (how much should the rebuild cost?)
Not necessarily a trans problem, although it could be. The switch on the column could be doing odd things. This is basically a toggle input to the PCM, so if it is being toggled by a short, or a ground, it could be an electrical issue.dont know about overdrive but its def a tranny problem and that might get pricy. the injector pump will be about 1000 bucks or 1500 for the high output pump....i know cuz i just replaced mine. its a crappy famous vp44.
