1998 ram Cummins 2500 Command start remote not recognized?
2197 Views 30 Replies 2 Participants Last post by  TuffyCalgary
Hi guys, I have 98 12v that came with a command start, but it is in need of rewiring to say the least. Anybody able to I.D. this unit? Thanks!
Wood Communication Device Gadget Technology Electronic device
Wood Mobile phone Pattern Landscape Electrical wiring
21 - 31 of 31 Posts
Ok update 1 Antenna was chopped in half 2 box suppost klick/ 4 times when u plug it in, mine clicked/flashed only twice. Went to junk yard got 2 more boxes and two antennas for 9 bucks . One of them actually clicks 4 times and antenna flashes like its supposto (didnt even think of antenna my own fault being a dummy) So box in truck antenna flashing just gotta figure out how to program it. If a guy changes antennas will it work with another box? Its got a push button on antenna for something. Thanks all!
It's hard to tell from your pictures but what isn't working? Is it locking and unlocking? Is it starting or not starting? Our trucks do have negative pulse at the ctm for lock and unlock but you generally need to five wire relay these.
That remote starter is a really shitty unit. It does not have very high current capabilities and our trucks draw a lot of current when they start.
The only thing you should need to get the truck started is first and second ignition, the starter, and a long enough crank time. We don't have any kind of security on the truck.
This is the wiring for your vehicle, take a look and see if it corresponds.
All the lights and stuff is working but it doesnt seem to recognize the remote..
Is that a thing? That the module does not recognize the fob? I have a Ct3471TW the remote came with the unit but antenna was busted off so i grabbed one from auto wrecker could this cause a problem? While I was there I picked up a bunch od different command start modules but none of them seem to receve a signal from fob. The fob is sending a signal out sooo any help?
They had different frequencies so somebody else can not unlock your truck.
And just found out that it needs a certain antenna 2. I figured it did but man trying to get info is like trying to get blueprints for a atomic bomb (super duper top secret)
Is Prostart a company still in businiess?
Yup they are but they are low budget and getting info from them is like pulling teeth
If you like it then, go buy a new set up for 2-500 bucks. Another modern brand.
Only help i have had is from Sales <[email protected]> Im not in love with ProStart but I have these antennas fmtw-121, sh433-120, fmtw-110, tw101, sh433-101, fmtw-130, sr433-100 fm433-100, fmtw-130, sr433-100 and sh433-100 and these control boxes as-1414 hf, ns-1054, as-1385fm, as-2383tw-fm-v, gs-1655 and mdl-2450v , trying to hold on to my $500 bucks
Yup you would think a guy is asking for nuclear codes
21 - 31 of 31 Posts
