1 - 2 of 2 Posts
Hey ive got my 1998 24 valve with 153,400 miles on it and it will only crank. It has never given any indication of problems, shut it off came back about 1 hr later and it wont start. cranks but wont fire. No check engine light, its got fuel pressure and a newer fuel filter and lift pump. It ran perfect and had plenty of power and showed no indication of any problems. Just went out abit ago and it fired right up like normal. Could you help me???
I can remember a buddy having a similar problem on a gasser a long time ago and I believe it turned out to be a relay that was starting to go bad, he just switched it around with another and it seemed to cure his problem. Not sure if these trucks are set up the same way or not. Just an idea.
1 - 2 of 2 Posts
