Hello all,
‘I have an issue that I have been trying to fix on my 1998 12v. I have read through all related forums with the same topic with no luck. I will start off with symptoms and backstory.
Manuel swapped 1998 dodge 12v Cummins. I mention that because I know from reading that the voltage regulator control in the PCM is somewhat related to auto trans wiring. ( I did this swap about 5 years ago and no issues until now, just wound up and zip tied above Manuel trans.
what I believe to be the original alternator, went out on the way to a desert trip. And lights starting dimming more and more until the batteries fully died and just kept the truck running until I arrrived, to look into it while I was there.
Confirmed alternator was dead and not charging, bought a high output XDP alternator, installed along with new batteries since I drained them so badly.
Now the truck is still not charging, and had a fried who is better at electrical help troubleshoot and test as much as we could with the help and suggestions from other posts. And have found that the blue wire from the PCM is not giving the alternator any power to charge.
I have followed the blue wire and did not find any damage or shorts,. I was ready to try and buy a PCM but am also reading that it is generally never the PCM, and that they are so likely to go out.
any other recommendations or experience with this that I should look into beforebuying and trying a PCM.
Lastly, I bought a cheap external regulator, but the more I read, the more I would like to try to have it working properly instead of more of a band aid.
thank you so much and anything is appreciated.
