Hello everyone, I bought this truck a few weeks ago and have been reading and trying to trouble shoot a fuel issue. The truck can idle for extended periods of time with no issues and rev smoothly. But as can be seen in the video, if I hold the rpm around 2k it begins to smoke, then miss, then smoke more, then bog down and if you let off the throttle it will die.
I can then restart the truck and it will idle again just fine but it is not driveable and the problem has not changed with the changes I have made.
video here .............. --------> copy and paste
I have replaced the fuel lines with the leroy diesel marine hose
deleted the fuel heater
new lift pump
new torqtek overflow valve
turbo is good
truck is straight pipe
I have also removed the afc housing and checked the fuel rack seems to be moving back and forth correctly. while i was in there i removed the fuel plate and slid afc foward in a attempt to see if more fuel would make a change. this was the last thing i did before the video. no change. except more smoke on the restart.
new lift pump
turbo is good
