I am going to attempt this. I bought both parts already ($300 without a swap, napa said I could bring my old mc and booster back for a refund????!!!!
arty018
and although it wont be a direct swap, it shouldn't be hard. I had to use both the 96 booster and master cylinder because the old MC won't bolt right up. The new boosters rod is the correct length.:stirpot:
1) It looks like the 96 booster will allow the vacuum hose to connect up with an adapter. Adapter Needed.
2) The bolt pattern is different so, I will need to drill holes and install another backing plate to accomodate the booster. Booster must clear the steering rod, throttle cable and engine in order to fit.
It should rain in a couple days, so I will attempt when I am off work.
THOUGHTS OR COMMENTS? ANYONE?
