Any one know what these 2 valves are called ones abs is the other combination valve can I get them from napa?
Yeah, deleted both and get an aftermarket adjustable proportioning valve.Could I just bypass the abs block all together. I been having issues with my brakes for a while I replace everything in the system but those 2 blocks
Ya sorry I didn't see your message. Bring the whole unit to Napa or your favorite parts store and get it matched up.Thanks for the info and part number I just oreded the valve. Do you know what size fittings I will need?
Did you have to adjust it or did the factory settings work ok. How did wiring the brake light switch go.Thanks guys for the help got the brakes fix used the wilwood valve put a new brake booster on. The brakes never work this good before.
