1 - 2 of 2 Posts
Im doing a swap into my F350 with a 1992 motor and I am using the Getrag that was behind it. I wanted driver side drop so I got a 1996 np241 trans case but it was behind an auto. Was wondering what i had to do to make it be able to fit behind the getrag since it came from a manual.
Thanks
Shep
Its likely that the input shaft will be different spline in which case you would have to find/buy a proper one and swap it in. Also you will likely need an adapter to bolt up the tcase to the trans.
If your lucky, I believe the input shaft can be changed on the 214/243 without having to change the entire planetary like the original borg warner 1356s that came in those trucks so chanves are it wont cost a whole boatload of money.
1 - 2 of 2 Posts
