1 - 10 of 10 Posts
Truck ran fine up until earlier today all of the sudden wouldn’t start doesn’t even make a noise but if you put it into drive on the lift it will start just fine need help
Super Moderator
There's a starter relay on the left fender the case needs to be grounded for it to work.
If it's only starting in drive then your shift linkage must be out of adjustment.
That sounds EXTREMELY dangerous.
Starting and running vehicles on lifts is very common, what is way more dangerous is a newb tech at a dealer who doesn’t understand how to balance a vehicle on a lift!!!! I’ve seen one tip over it wasn’t pretty especially with a brand new powerstroke on it!!!!!
Sounds like worn or mis-adjusted shifter linkage, and not engaging the neutral safety switch properly. I would remove all the shift linage, clean lube and re-install then re-adjust everything.
Super Moderator
Since this happened like overnight you might check your body mounts, something must have shifted to throw off the linkage.
1 - 10 of 10 Posts
