Alright, update time!
1) I finished up rebuilding the VE injection pump. Krud Kutter on the rusty bits and bobs, some replacement screws, and some elbow grease, along with a new seal kit and installing the upgrades, and the pump looks great. Ready for action.
2) I completely disassembled the NP205 transfer case, cleaned all the parts and inspected for wear, took a grinder to the shift rails as part of the twin-stick mod, used Rustoleum Rust Reformer as a base coat and Rustoleum Hammered Black as a top coat, then reassembled everything with all new seals. It looks really nice!
3) I did finally finish busting out all the rivets from the front crossmember on the crew cab frame, and disassembled the frame completely. I attempted sandblasting myself, but after one crossmember with my 60 gallon compressor, I gave up and called the professional. Frame goes to be blasted as early as this weekend. I had previously ordered a body mount and bushing kit from Energy Suspension which replaces the rubber mounts and bushings with Prothane polyurethane. Only when looking over the front shackle hangers and then the rear hangers did I realize that a) all of the hangers have bushings which were not part of the kit, and b) nothing in the kit will fit the rear springs or shackles to begin with. So now I'm on the lookout for rear leaf spring and shackle polyurethane bushings.
4) I finished the tear-down of my 12v and took it, along with the pistons, crank, flex plate, rockers and head, new bearings, new rings, new cam bushing, and new valve springs, all to the local shop so that the engine can be hot tanked, crank balanced, head and valve seats checked, rockers milled for headstuds, and 60lb over valve springs put on. It's been there over a month and I haven't heard anything back yet, but I'm not rushing the guy because it isn't holding me up.
5) I have completely torn down the transmission and inspected everything. The rear band was worn to the point that flakes of clutch material were coming off. However, the frictions and steels and the front band actually looked decently new. I noticed several upgraded parts already in place, including two steel 5-pinion planetary and the high capacity direct drum (it has the two parallel lines on the outside indicating high capacity). I completely cleaned up the valve body and installed the Transgo shift kit, as the valve body appeared stock, along with new OD/Lockup solenoids. I plan to replace the accumulator, servo cover, apply lever, strut and anchor, and rear 4-pinion aluminum planetary, with the quad-seal Sonnax accumulator, Sonnax o-ringed servo cover, billet 4.2 ratio apply lever, billet strut and billet band anchor, and 6-pinion steel planetary. I'm also planning on upgrading all four clutch packs with Alto Red Eagles and kolene steels, and doing a complete re-gasket and reseal of the transmission. The case has already been cleaned and painted with self-etching primer and a coat of Rustoleum Hammered Black to match the NP205 transfer case. It also looks great, and I can't wait to get in the rest of the parts so I can begin reassembly. (Also in store for the transmission is a Goerend triple-disc torque converter and deep transmission pan. I really like their design. In the event I ever plan to eclipse 450hp, I'll install a billet input shaft. For now, however, that's an expense I can forego.
Pictures!
(This doesn't even look like the same pump anymore)
(Dropped the pan)
(Stamped the bottom of each rod to keep them in order)
(Transfer case teardown)
(twin-stick modification)
Pictures!
(Dropped the pan)
