Ok so I don't know how projects are accepted on here. If its inappropriate please just delete it. I started out with a 51 GMC pickup body I found a 2000 Cummins with a 2002 5.9 the guy that sold it to me lied about the engine being good. But I parted that truck out and got all of my money back and still have the frame that I plan on using for the build.
I bought another 98 Cummins chassis with a sweet running engine so that put the project back on track. I have the 2000 stripped to the frame I am going to use the axles from the 98 it has 410 gears the 2000 had 353s. I gathered up a five speed setup the trans needs rebuilt I have the parts ordered should be here next week. If I use the pickup front fenders I will have to move the engine back 12 inches to get the wheel wells to line up and still have room up front for the radiator and innercooler I plan to cut the motor mounts out of the spair frame (that truck was t-boned ant the frame is bent anyway). Probably have to do some custom work on the firewall as well. I bought a pickup box the right vintage but I starting to think I want a flatbed.
Nice. Projects are permitted, a mod will likely move it to the proper section is all.
Reactions: 9297oldram
Super Moderator
We like projects, I moved this to the Conversion Section where you will find alot of projects.
Just keep adding to this thread with your progress and when you have time look at some of the other Members Conversions.
I should add we have a ‘53 GMC as well, but half ton. Since it’s Canadian built it’s not a 100 series, they labelled it a 9314 for some reason.
Ok so I don't know why I said it was a 53 GMC its a 51. But anyway I have made a little progress on it. I stripped the axles and suspension out from the bent frame and got them bolted up under the shortbox xcab frame I pulled the cab off the 51 frame and started mock up. I got the cab set on the new frame its just sitting on blocks so I can get the wheels centered over the tire and get the height right I think it looks about right. So now I will start fabbing body mounts then start working on moving the engine mount. But progress was made.
Super Moderator
I changed the year for you. If that's the tires your using then it looks like the cab is sitting ok.
Reactions: StealthDiesel
I had to raise the cab about 4" to get the tires to clear the front fenders and to get the grill to fit. I think I will be able to trim the Dodge body mounts and use the rubber isolaters from the Dodge should make that old tin can cab a lot quieter.:cool:
