well gonna break down and get some vision 81's and hankook dh01 265/70/19.5. found a lot of info on wheels tires etc. But i was wanting to know if anyone had any problem with ball joint wear or any thing negative about running such a heavy setup. i smoked my factory ball joints at 63000 with 17x10 alum wheels and 315/70/17 bfg all terrains any input on anything you think is helpful would be appreciated thanks
hydraulic lifter crew
yes it will be harder on the steering. i ran
285/70/19.5's on vision rims and they weighed
in at 132 lbs. prior to that i had 17x9 rims
with 37x12.50/r17 and those weighed 85 lbs.
your basically putting another 50 lbs per corner
on the truck. i loved the ride it gave and towing
was fantastic. i did a swap to a dually and will
prolly get another set for it in the next 6 - 12 months.
Welcome to CF, might want to post up in the tire and wheel section. You will get more feedback there. "TurboTbird" on here runs the 19.5s and loves them.
Reactions: decil
yea the weight is up there and that was my main concern especially since i just dropped 358 bucks for ball joints.. however i don't like the way my truck tows with the 315's and that was my main reason for looking at the 19.5s i don't think there will be any give in a 14 ply tire ha ha
the 285's i ran were 16 ply and i loved em.
towed really tight, no sidewall squat, and
a nice firm ride. here's a pic of it when i
had those mounted and the truck was a srw.
sweet deal your truck was almost identical to mine minus that glorious cow catcher don't have that yet. i also have the single wheel did you have a a leveling kit and any rubbing?? i got a 2.5 leveling spacer and figured the 265's wouldn't rub wasn't sure about the 285's
Discussion Starter #8
well good to know i figured that every thing would clear tires i have now are same height but 12.50 rub just a little but all should be well with a 10.50
