1 - 11 of 11 Posts
Banned
just got back from the track...best time of a [email protected]!!! :woot: with just the mods in my sig. won a $20 bet with my friend. lookin to get a 13.9 with water injection and some better tires... although I pulled a 1.9 60ft.....pretty good for a 2wd, huh? :peelout
yea, that was on 265/75/16 street tires @ 20lbs of pressure, launched at around 9psi of boost.
WOW 9psi,I can only launch at 2psi or it will blow the rear tires off, same size tires with around 28psi,my best 60" is 1.94:thumbsup
$20, shoulda bet a tank of fuel for either winner!!! LOL, that's great man, must have gotten on a sticky side of the track, and had your tires good and warm for such a good 2wd launch!!! YEEHAW
Banned
yea, I drove around the water, spent a couple seconds warming up the tires, and hit right at 9psi when the last yellow flashed... then at around 25mph, I hit my lock-up switch w/ OD off, hit OD at around 55mph
Banned
when I get a bigger turbo, I'm going to run a two-stage boost controller, cuz I hit 35psi damn near right after I launched, and a couple times I lost traction, so I'll have it staged when I go to my 35/40 hybrid... gonna run about 45psi max and 150hp injectors and water injection.....THEN i'll have to figure out how to launch again, lol
Banned
Discussion Starter · #11 ·
35psi is the top of the compressor map for the hx35, I think with a hx40 compressor wheel and housing at least 40psi would be optimal.... wouldn't it? I mean it flows way more air than a hx35
1 - 11 of 11 Posts
