1 - 20 of 295 Posts
This might be sacrilegious and probably frowned upon by many, but oh well. I'm tired of having moose antlers for mirrors with a tiny bubble mirror. So I decided to do something about it. I put current style Chevy tow mirrors on my 06 Mega Cab and it came out really clean. All the lights on it work too, including turn signals, marker lights, defrost, and the little backup lights. Let me know if you have questions.
Subscribed
Very nice! I'd love to do this to my 2012.
Please share a detailed write up!
Following awesome
subbing to this
I can't see the pics, is it my phone?
I really want to see this!
Never mind, i can see the pics on my laptop...
Looks good!
This is of great interest to me as i have manual mirrors on my Ram,... every time i hook up my trailer i have to deal with re-adjusting my mirrors. Power morrors would take care of this but i would need to add wires, switches, inner door panels, plugs.... my truck is a ST model, power nuthin!
Well, it did come with a Cummins! :D
I expect these mirrors would be adjusted and work in the 'in' & 'out' positions w/out RE-adjusting....
I found these....
https://www.1aauto.com/mirror-pair-trail-ridge-trmrp00012/i/trmrp00012?f=1093512&y=2016
Discussion Starter · #17 ·
So I don't have a write up exactly for the Chevy mirrors. It was more or less just a tinkering thing until it turned into a feasible project. I'll try and make a video or something when I get back home.
Also, there's no wind/road noise from these and they're more stable than the moose antlers.
subscribed! A write up, video, or any kind of install details would be greatly appreciated by all! Looks completely factory and those mirrors are a step above our stockers or even the 4th gen powered mirrors IMO...
think you might have started something here ;)
Discussion Starter · #19 ·
Ok so I am still out of town but i know you guys are curious, so I will kind of give a run down of what I did while I'm here in my hotel. First off, heres a link to the mirrors.
2014-2017 Chevy Silverado GMC Sierra Power+Heated+Smoke LED Signal Tow Mirrors | eBay
They are by no means plug and play.
Since I've done the hard part already, measuring and testing; getting them on is pretty straight forward, just time consuming.
The attached image is all the measurements I had to take before I was confident to spend 200 plus dollars on something that shouldn't work.
The top triangle is the dodge mirror and the bottom, the chevy. I got those by going to a chevy dealer, asking to see a mirror from the parts depot and literally stood there for 30 minutes getting measurements while the parts guys stared at me.
1. there are 4 bolts on the Chevy mirrors, you only use the 3 corners, not the 4th middle. You'll see when you get them. You will use the front bolt to measure for the other 2.
2. luckily for us with 3rd gens, the front bolt aligns everything else up to be where it should be. by using the front stud as a guide, you drill the rearward hole about 1/8 inch farther back and the top hole about an inch higher and 1/2 inch back. (this is all by memory and each truck might be different, you still have to measure some)
3. after the holes are drilled you can now start to grind the die-cast metal mounting surface of the mirror. basically everything gets trimmed ~1/4 to 3/8 of an inch all the way around. your goal here is to make the mirror sit deeper inside the mirror pocket on the door so the surrounding plastic sits flush with door (again, you'll see when you do it)
4. after everything ground and you are satisfied with how it sits and is level, you'll need to tap a few holes. you can choose to keep the bottom 2 studs or tap them and put in different studs like I did. I chose to tap because there is a lip on the chevy studs that gets in the way. the top hole will have to be changed to a longer stud or a bolt because when you drill the hole in the door for this one it goes right through a thicker part of the door. ( again you'll see) the tap i chose was a 5/16 18 just because I happened to have studs that size already.
5. after you found the right attachment hardware and done being giddy about how it looks on the truck, you'll need to get a different gasket. this is because the plastic surround is ever so slightly lacking in length towards the back. luckily for us 3rd gens, you can just use the factory dodge gasket. its longer that the chevy one and offers more sealing power. WIN WIN.
6. now if your truck came with power mirrors and heat, your in luck, if not, god speed then. mine has power and defrost and so do the mirrors, however, the plugs are way different and reversed male to female. so now you have to do a bit of wiring. i chose to cut the female plug off my dodge mirror and attach to the wires on the chevy mirrors then theres no fuss. I wrote down which wires go to what but its at home and I can upload it at some point.
7. as far as the other lights go (turn signals, marker and back-up lights) you can wire those to whatever you want. I chose to wire the turn and marker to the front turn signal lights and the back-up to an auxiliary switch panel I made a while back.
an optional thing you can do is turn those marker lights into turn signals and marker lights by way of using a couple diodes and a resistor. I did this and its amazing. also the red turn signal built into the mirror face is bit bright so I added a resistor to that circuit as well.
now I know this is not very detailed but it should help to paint a picture of whats involved in doing this.
I also appreciate all the positive feedback and I hope a I started a new trend to get rid of those abortions dodge decided to call a mirror. adjusting them every time you go from moose to non-moose? F off, what stupid design, no wonder we get so much $h!t from people about towing ghost trailers, its because its a pain to adjust them every time, especially if your motor functions don't work. Ok, I digress. I hope you found this helpful
Thank you Sir, this is good. I totally agree with the last part of leaving the mirrors up because of the pain of re adjusting...
I wish i could find more pics of Rams with this kind of mirrors... I would like to SEE it before i buy!
1 - 20 of 295 Posts
