Another step in "preparation" was moving the exhaust outside of the frame rails since this trany is so wide there will not be room for it and the exhaust.
I run a 5inch exhaust with a resonator and a muffler. Here is where I started
I made a "custom" down pipe that goes around the A/C receiver tank then comes out through a cut in the inner fender and over the frame rail. I had to use 4inch here to get the bends tight enough.
Here is a picture of the finished exhaust from underneath
from the side including squashing my 7inch tip into an oval so it didn't end up too low to the ground.
