1 - 20 of 28 Posts
I'm lookin to buy another truck for sled pulling and need some opinions on which truck I could get the cheapest power out of.
P-Pumped Beast
how much power for cheap?
400hp
500hp
600hp
i cant give my opinion without your ultimate power goals.
Shootin for around 600HP
Even at low HP the 24V is more if you look at small stuff thats not performance. Like Retainers and keepers are alot more. Valves and some of those things that have twice as many parts as the 12V. And i look at it like this. Less moving parts, less chance or breakage. So unless you already have a 24V your wanting to build. I would buy a 12V
12 valves are badass go w/ it less complicated to... when i bought my truck i coulda bought a 04 4 door 5.9 6spd 4x4 but i decided to buy the 12 valve just cause i love 12 valves and they are easy to make run all you gotta do is turn it up and take the torque plate out and they"ll run like a bat out of hell
you can get a cheaper start with 12v but they all get high as you go bigger power
True.
you can get 400hp cheap and fast with a 12v but much more than that and you are spending alot. In all honesty go with the common rail 24v they are taking control here now. More power for bout the same money and on top of that the engines are tougher so you don't have to replace studs ect. as fast
I know the 12v guys will argue this but it still holds true.
a common rail is way more expensive then a 12 valve . i think he"s talkin about buyin a whole truck. if i was you i would buy a 97 12 valve as you cab buy em cheap
1 - 20 of 28 Posts
