1 - 16 of 16 Posts
Not enough to note a change on the dipstick.
Same here ,next to nothing. Just under 220000 KM
Even with over 270k miles on both my rigs the level barely changes between 10k mile oil changes.
Never had to add a drop even since the trucks were new but I do 12 qts with every change.
Since I did the KDP and sealed the cover it uses next to nothing. 196K miles
You have to put oil in these trucks? Uh Oh, I'll be right back.
240,ish. Uses no oil. Dribble under the blow by sometimes but that's it.
guess il be the first to admit mine leaks/ burns oil. i will notice a few drops under it each night not sure where it comes from or id fix it but i will go from a hair over safe when i change the oil to half way or more down safe by 5k mi.
i am very suprised all these people are saying they don't have this issue i know alot of people on here do have leaky engines
on my 95 with 300000km on it or 180k i never see drop in the pan, I actually had wonderd, If diesel was geting in the oil pan filling it up "on the go" but guess these piston rings and HG work like they the should
I take it to mean burn oil, not leak oil.
Leaks are easier and cheaper to fix than oil burning.
I don't know about others here but I fix oil leaks right away, they don't usually get better on their own.
I'll admit mine leaks oil, but it's from the front diff cover
217k and mine leaks a small puddle from the front cover on an overnight sit on concrete. thats why i park or gravel haha.
I know more than a few ctd men that have a well lubricated undercarriage, and dont know where the undercoating is coming from!!!!!
Same here. My engine wasn't always leak free...ish.
Changed oil and filter 3000 miles back, level has not dropped. I check the stick once a week, maybe two. I drive close to 100 miles daily M-F.
1 - 16 of 16 Posts
