1 - 12 of 12 Posts
Well howdy from down under.
heads up if you have no clue what I’m on about just search google and throw Australia at the end or ask me. I’m more than happy to explain. I am a qualified mechanic by trade and can never get enough of cars.
I have myself a little project going on at the moment, me and my wife (beautiful woman she is loves cars as much as I do and probably spends more on hers that I do on mine :LOL:) are undertaking this with the ideas of getting it on the road and done under $15k aud here is the rundown.
We already own a 2004 Nissan patrol with a zd30 3.0L (known as the grenade) in-line 4 turbo diesel with a 5 speed manual Australian delivered that does 1-60mph in about 2 years and 3 engines. It has 420000km or 260000m on it and the zd30 is lucky to make it past 150000km/93000m, we want to go touring Australia and want reliability so it’s gotta go.
The patrol is a great car to drive tour and 4wd in they are big in Europe, Middle East and down here they came with a few engine combos but they each have there own issues. If you really love the car you will usually end up buying or converting it to the td42 4.2L turbo diesel (known as the kettle). I was not to keen on throwing that in as they are know to get hot very easy hence the name, or snap cranks. Plus the engines cost around $6000aud for one in decent shape with all the ancillary’s in factory form and to even get to 200hp is $5000+ The amount of work swapping one of them in is about the same as anything because you have to cut the engine mount brackets off the chassis and weld on new ones.
Now the aftermarket support for these cars is just amazing. Seriously you think of it someone Has can or will make it.
I was looking at other option for a swap eg. Td42, ls1/2, duramax or the mighty barra but landed on the 6bt after I learnt about them and there straight up bul****t power reliability and how much of an amazing engine they just are.
So since the end of last year I have been in full recon mode searching and learning about them. I ended up getting a 1996 12v 215hp engine from a ram 3500 from a company called texstar for a pretty nice price compared as to what they sell over here in Australia ($7000aud+). When it rocked up I quickly shot down to the freight company and jammed it in my trailer and unloaded it at home. So my first instinct is give it a good look over and see what I’ve got and get it started on the pallet. what I found was it has arp headstuds, 4K governor springs, emotor USA hx35 turbo with the wastegate wired shut:eek:, timing bumped up to 16 degrees and a few missing bits and pieces. Nothing that will stop me from getting it running. So I borrowed a flex plate from a connection I had made through some pages for the conversion I’m doing on Facebook. Hooked up some jumper leads from my battery and got a very slow crank. Hmm ok 2 Batterys and 2 leads, same slow crank. Ended up having to buy a roll of 00 guage wire and make my own leads with battery clamps and run it straight to the starter just to get it cranking to Re-bleed injectors and get it to kick. But she ran, And she ran good. Next to no blow by and no bad noises, onto the next step strip, asses, refresh, paint and order all the bits.
Gearbox options for these are pretty few. You can buy an adapter kit off the shelf and bolt it up to use the factory 5 speed manual. Only issue is once your at 300/350hp they shred the gears and your up for a new box. You can go Allison 1000 or 4l80 with the cost of $10kaud Upwards is a big no. You can run a Nissan/jatco re4 auto but you have to spend some coin to make them take the torque. So only real option is factory Dodge box. So I got myself a 1994 47re from a p pump with the Pcm and wiring harness to go with it.
You wouldn’t believe it but someone actually makes an adapter plate to go from 47re to factory transfer case. So that’s the go for me and they are only an hours drive! :D He also happened to have a hx35w for cheap so I grabbed that.
Engine mounts are easy plenty of people make the kits for them and they are readily available.
So that’s the major bits done and out of the way. Onto the more Cummins specific side of things.
As the engine sits it is now stripped to long block with the oil filter housing and front cover still on. I need to get a gasket kit so I can replace every gasket I can see so I don’t have to worry about leaks, and I need to get some new injectors as they are mismatched and the injector line seats are all damaged or falling apart.
My plans are to send the pump of get it cleaned and checked so it’s 100%, paint and clean what needs to be cleaned and start to reassemble and get it ready to go in.
A few questions I have is what are your opinions on Power Driven Diesel and there products I want to buy there 47re auto kit and afc live and a bunch of other stuff but want to make sure I’m spending it on good gear.
Next is does anyone have the service specs and tolerances for a p-pump while getting serviced on a Bosch test bench.
next is I aim to run around 300hp and not one more. What will the auto need to hold that power I have read that it’s pretty basic but I do not mind stepping over budget for the right gear, same for the engine I have read that the 4K gsk some afc mods and an afc live will get me there with the hx35w. But I have read that you should do 60lb springs. Is the absolutely essential or can I get away with the hardened retainers?
Next is coolant bypass kits. When do they become necessary? There is next to no room between the firewall to fit them when in the car so I was wondering if there is another way around this like using the rear coolant sender port down the back as a bypass and tee the sensor in line?
I think that’s about it for now looking forward to hearing from everyone!
Thanks for making it this far if you did read all the way!
Super Moderator
Looks like you'll have a nice truck when it's finished, if I was you I wouldn't use a Dodge computer just for the transmission. I used this on my 47re in my Blazer build and it's so easy to use. Dodge Transmission | E-TransControl
Discussion Starter · #3 · (Edited)
So the gearbox turned up today.
took it home and threw it in the engine stand so I can work on it on there. Took the pan off so I can let it drain overnight, while it’s off I will weld a drain bung into the pan so I can change oil more regularly.
They look in pretty good shape. Only on plug missing so won’t be to bad at all to work with!
looking over the trans and some other info it’s looks like it’s a 47rh. Can anyone confirm for me?
2006 Dodge Ram 2500 SLT QCSB
What a cool project! Yes if it's from a 94 it will be 47rh. All hydraulically controlled except for the overdrive and tc control, which if you have the ecm for the engine, I think it can tie into that for overdrive control, otherwise you can make or buy a pressure switch that will lock /unlock tc and overdrive based on your speed, can also do manual switches for those two functions if you desire, pretty much endless possibilities. I found this article that talks about that concept a little more
Sent from my Pixel 3 XL using Tapatalk
Dang! Did a bunch of measurements yesterday just to see if the rh was usable but no go! The factory patrol manual is 680mm long from bellhousing to transfer mating surfaces and from looking around the re is 680mm from bellhousing to transfer. The rh Is an extra 110mm to longwhich means the transfer will be pushed back into the chassis crossmember after adding on the adapter plate and I really don’t feel like doing chassis mods.
I have contacted the company that supplied it and they are working with me to correct the issue. So fingers crossed we can sort it out quickly.
Hello. I have a y61 gu with a 6bt already. It's a 5 speed manual. Got my hands on a 47rh and I'm interested in the 47rh to patrol transfer case adapter. Can you please give me the info of the company who makes it?
Thanks
03 superduty,12v 215 p pump,zf6,he351
how this project going
Discussion Starter · #11 ·
Thanks
Hey rolo. Seen you around in the 6bt patrol page on Facebook. Few places make them. Ramit conversion and C.E.M both in Australia. I know your over in Costa Rica.
Discussion Starter · #12 ·
Ran into a major issue.
I was gearing up to clean it and paint the block, decided to pull the timing cover and replace the gaskets so I got the rocker covers off, de-adjusted the rockers, pulled the circlips, slipped the rockers to the side and found this
929418
Red rtv and metal shavings in the journals. In every one.
Took the tapper cover off, pulled the pushrods out , pulled the lifters up, zip tied them in place, undid the retainer for the cam and pulled the cam out and found this
929420
Nearly every second lobe had pitting or the tops starting to be worn away.
at this point I decided I was going to keep going until I stopped finding issues. Heads up I didn’t stop.
Pulled the head, found .6mm lip on #6 bore.
929421
929422
At this point I decided it’s going to be rebuilt. Striped the block to the rotating assembly.
929424
When I took the sump off I found another surprise.
929425
929426
all bits are magnetic, checked over the pistons and rods could not find where it came from.
So I called Cummins Brisbane, they use hm gem engines so I took the bottom end and head to them to be redone. They inspected it and confirmed the engine had been rebuilt before, this time around it would require 6 sleeves and new pistons. Rods and crank all good. The head failed leak test and a crack was found from the valve through to the port on the exhaust side and needs a new head. This is where it is now.
$3500 in block repairs and I’m waiting on a new head to arrive so I can get that all happening.
I have decided to put a Hamilton cam package in it (cam, lifters, pushrods, springs, retainers and valves) because why not I’m already here.
I’m thinking of getting the marine big bowl pistons but I’m not sure if anyone could give me advice on what would be best I would love it.
the reason I’m leaning to them is more timing and power.
So this is where I am now and I will do a photo dump later when I get home from work of some more stuff from pulling it down.
Reactions: J.R.R.
1 - 12 of 12 Posts
