1 - 4 of 4 Posts
From the app screen, I can go into settings and display, and choose light, or dark, easy enough, but what does "auto" do? I assumed it would go to light mode during the daytime, and dark mode when it's dark, but it stays in whatever mode you last chose, and doesn't change.
maybe it changes with the headlight switch being on or off?
It's supposed to, but it's just another electrical screw-up on this particular truck. Usually I get three beeps when I walk away from it with the engine running, today it quit doing that, which is a good thing.
The three honks is an indication that the key isnt In the vehicle when the truck is running. Asserts when you shut the door, usually when the key is in your pocket outside the truck while it’s running.
It was an addition to the Dodge/Jeep programming for 22. No way has been discovered to disable yet.
1 - 4 of 4 Posts
