1 - 12 of 12 Posts
My manifold is leaking and starting to warp at 183K. I'd like to replace it before a bolt breaks off in the head. 2 or 3 piece manifolds used to be the consensus on 12 valve heads because the warpage could break off the ears on the head. Obviously that's not an issue on a 3rd gen head. I'm looking at the 2 piece DPS manifold and the AFE bladerunner 1 piece as they're the most affordable. Opinions on the benefits of a 2 piece for a 3rd gen?
TECH SPECIALIST
no experience with a 2 piece but the AFE SS Bladerunner I have has been solid as far as I can tell. I did have a broken exhaust manifold bolt on the #6 cylinder, next to firewall. No idea if the mani had anything to do with it, I suspect bad shocks on a dirt mtn road and not going slow had things bouncing a bit more then they should have been.
Did you break the bolt with the AFE on or was that the previous manifold?
TECH SPECIALIST
it was with the afe and after 5 yrs of service... i have a thread where we discussed the bolt removal, pics r there and there was no manifold shrinkage. i have the SS one...
The oem manifold was shrinking on my 03 HO and KT Performance had the best price on a 2 piece. I gasket matched all ports including the outlet and turbine housing on my II PS and it lowered my egt about 100 degrees. Get one! Craig
2 piece manifold is a GREAT time to swap to 2nd gen design , good flow and get back the proper cummins sound that the 3rd gen manifold destroys .
Discussion Starter #8
I'm worried mine are about to break since a few are visibly bent. I had a bolt break on my old 12valve and it took two days to get it out! I'm not really interested in the 2nd gen swap as I don't want to have to change a ton of stuff and my egts are never an issue in my usage.
I'm thinking I'll go for the 2 piece. Thanks for all of the replies!
Even a new Cummins 3rd Gen exhaust manifold would work fine.
Cummins re-designed it a few times, adding material for greater durability.
There used to be tons of used aftermarket 2 piece 3rd Gen ex manifolds around as most guys go to a 2nd gen ex manifold when they go with a bigger turbo or twins.
Discussion Starter #10
Heres another question- does anyone know if the Borg SXE-300 series turbos have any clearance issues with the 2 piece manifolds? The joint looks pretty hefty and like it might get in the way of a turbo in some situations.
Discussion Starter #12
ENded up going with the DPS 2 piece. It's a very very nice piece. Definitely high quality and given it's the cheapest aftermarket manifold out there (other than the knock off ebay ones), I feel like it's a steal. I used stainless studs and nuts from purediesel power and a sure glad I did. I don't see how you can get the turbo on and off separately and turbo plus manifold is so damn heavy, it would be a huge PITA to try and use traditional bolts! I soaked all the old bolts in aero kroil for a week and sure glad I did. No bolts broke but dang, they were really close and the #1 cylinder holes needed some thread repair the old manifold was so warped!
Didn't notice any driveability changes. My Egts are never an issue. Maybe a little better boost, and less noise now that there is no leak!
1 - 12 of 12 Posts
