Yes for right now because Dodge trucks are the only thing around here for a donor truck.Are you guys going to be specializing in Dodge suspensions?
To answer your question I guess is I like a challenge and second of all when I first started this project I was trying to turn 33"x15.5"x18" on 10"x18" rims with only 2" of lift with out rubbing and with my after market front bumper I had a lot of room between the bumper and tire compared to backside of tire to fender .Im curious as to why you are going with 1" longer arms. We already know that 1/2" longer arms work great, so why are you going through all the extra work to gain another 1/2"? What are the benefits that you gain to offset the amount of work it takes to run them?
Truthfully I don't think they really need sleeved but when Titan Machines builds something I like to go the extra mile and build it for the WOW FACTORwhy sleeve the bottoms and not the tops, or even sleeve them at all?
I follow... Thanks for clearing that up!!!shock length does not determine lift - only coil spring length. Shocks are available in different lengths - not for adding lift, but to make sure that they are not the limiting factor in suspension travel.
The shock towers were designed so I could run the same part# of bilsteins that are in the front as I have in the rear .Here's a question for ya... Those shock mounting towers... are they the same heighth as stock ones or can they be made an inch shorter to gain lift?? Sorry it this is a stupid question...
