1 - 10 of 10 Posts
ok so i've got the lights and if i cannot sell them, i would like to put them on my 06.
i tried this on my last 06 and everytime i was to get it wired up, it would be a constant feed when blinker was on so i put my 06 lights back on.
i am very electonically inclined so someone please tell me how to do this.
i also, however, thought about wiring them to my trailer wiring but then i'd have the fast blinker, lamp out, etc haha.
i've seen 06 lights on 07-08's so i'm sure i can be done my way.
· Pursuing the Great Commission
driver side of the 06:
Pin 1 - White/Yellow - Tail lights
Pin 2 - none
Pin 3 - Black/Green - Ground
Pin 4 - White/Tan - Brakes
Pin 5 - White/Dark Green - Left Turn
Pin 6 - White/Light Green - Reverse
passenger side of the 06:
Pin 1 - White/Gray - Tail lights
Pin 2 - none
Pin 3 - Black - Ground
Pin 5 - White/Yellow - Right Turn
can't get to the 08 stuff from this computer, so I'll get that after while.
driver side 3 pin connector on the 08 :
Pin 1 - White/Dark Green - Turn signal/brake
Pin 2 - White/Yellow - Tail light
Pin 3 - Black/Dark Green - Ground
Passenger side 3 pin connector on the 08:
Pin 1 - White/Yellow - Turn signal/brake
Pin 2 - White/Gray - Tail light
Both sides 2 Pin connector on the 08:
Pin 1 - White/Light Green - Reverse
Pin 2 - Black/Dark Green - Ground
in this case, since the brakes and turn signals are the same, it might be easiest unless you want to add diodes to tap off the trailer plug for the controls to the light, and just have dummy resistors in the turn/brake wires to keep from fast blinkers.
The other option is to use 2 diodes to feed/isolate the turn/brake circuits on each side.
hope this helps.
sounds good, i'll try it later today.
i ordered recons just incase i decide not to do it haha.
thanks a lot man!
thanks a lot man!
was thinkin about tryin to black out the lights on my truck but wouldnt mind an extra set in case i mess em up. let me know how it goes, more really if you just dont like em. because if you cant get them to work on your 06 doubt i would have much luck on mine anyway :thud:
:thumbsup if you get the 08s working I might be interested in the recons
bump it up....Has anyone done this?
· Piggy Piggy
Dropped my truck off at the dealer after they said all yea no big deal we can do that.I showed up the next day still with 06 tail lights in the truck.Guy said something about it might fry the tipm so I really have no ideal.I would love to do it tho
1 - 10 of 10 Posts
