Anyone? Anyone?
But, is it legal to delete those two?
Bluntly, NO but do it anyway
I live in Louisiana. Do they check for that kind of stuff? check your states emissions/inspection laws. Here in CT, any vehicle with a GVW GT 10,000lbs is not subject to emissions testing. we also have no annual inspections except for Class 6,7 and 8 vehicles in other words, buy the 3500
I wish they made a dpf replacement to look like the real thing so they wouldn't know by just looking under? there is a rumor that someone is working on such a piece
Can I purchase a dpf delete that just gets rid of the original dpf and uses the rest of the truck's stock exhaust? yes I am waiting on the new downpipe and dpf delete pipe from there into the factory exhaust
I will need a fooler box also. correct
But is there a fooler box for the egr delete yet? not yet, but it's in progress
Isn't this wonderful - you have to spend 50 grand on a friggen truck then dump 3 grand more + labor on crap just so you can drive it and not have to sit at the dealer dealing with idiots WTF is wrong with this picture?it's a bolt-on job. you need a straight pipe that replaces the piece of exhaust that houses the DPF and a fooler box. You want to put a replacement 4" downpipe on as well (also bolt-on, no welding involved). It will take you 3-4 hours if you know that righty is in fact tighty. the minimum you will need to delete the DPF is ~$1050 from BADP. It includes the 4" delete pipe, the 4" downpipe, and the code-free fooler box. For another $60 you can get the EGR delete plates from K2 Diesel Performance here on this forum. Those will throw a CEL and you can choose to either ignore it until a code-free EGR delete is released or buy an Edge Juice w/Attitude ($800) or Bully Dog PMT ($1000) to clear the codes.
No arguments there but all three manufactures are forced to meet the standards by 2010. Not only will dodge be having this headache.:thumbsupIsn't this wonderful - you have to spend 50 grand on a friggen truck then dump 3 grand more + labor on crap just so you can drive it and not have to sit at the dealer dealing with idiots WTF is wrong with this picture?
Here is a link to the PDI, which is the distributor for H&S. However, i no longer see the H&S kits listed on their website. You might want to give them a call and figure out what the deal is if you are interested in an H&S kit: Performance Diesel Inc - 07.5 Cummins 6.7LThanks bronco! It seems as though the dpf and egr delete puts new life into the 6.7L. I'm assuming both deletes can be reversed. I was looking at edge products and found the edge Insight. It simply plugs in with no hp or torque increase potential. Would this cheaper Insight erase the soft codes just as attitude with juice? Thanks fellas! Where do you find H&S dpf delete on the internet to order? I've found BADP dpf delte and plates for egr.
Hey JohnBut, is it legal to delete those two?
What's stopping us from gutting them? Have you , by chance, seen the inside of one? I'm wondering if it can be done.
I'm not due until 2011 for inspection, I'll put it back on then. Planning on flanging the muffler end so it will be just a bolt in. But then again, I am in the process of Dodge buying back my truck so it may actually be 2013.
And what's this about a 3500 being exempt?
The insight has the ability to read and clear codes but it cannot be programmed to automatically clear codes before startup like the Juice w/Attitude and PMT can.Will the edge Insight remove soft codes just at the edge attitude with juice?
