I recommend the Shibby Engineering EGR Cooler & full Delete kit. You will also have to delete the exhaust and run an aftermarket exhaust system, and have to buy a tuner to turn off the sensors in your ECM so it won't throw your truck into limp mode and fry the ECM.
If you don't want to go that route with doing full deletes, then I recommend buying a used EGR cooler from someone on here.
