The sensor that's used for that is your rail pressure sensor I believe. It's bassically a check sum. Fuel pressure is not required.
Do you a have a gauge on ur fass. Is it pumping fuel?
Have you done a return flow.
I highly doubt it's your pump. However u say MOST of your injectors have been replaced. thats where I would start. Also check the relief valve on the rail. Is it making oil?? Probably worth a 25 dollar sample to determine that.
If all else fails it's
Most likely an injector.
Sent from AutoGuide.com App
