1 - 1 of 1 Posts
New to forum so any help greatly appreciated. I have a 06 Dodge 2500 Mega Cab 4x4,5.9,auto trans, all stock with 115k miles. I have had the usual trans bucking problems and have replaced the gov solenoid and pressure sensor. Before replacing it would hang up in 2nd or "hunt",now it hangs up in 1st. Will adjusting the bands help or replacing the TPS help? It seems to be one certain spot in the throttle position. If you start slowly it will shift fine but if you start normal it will not shift out of 1st unless i back off the throttle. Thanks for any help.
1 - 1 of 1 Posts
