Does anyone know if I buy a set of 06 taillights will they fit on my 08? :confused013:
I think they will. I have a 2006 bed on my 2007. When I called the dealer they said the part number for the bed was the same for 06 and 07 I think its the same from 03 - 08. Hope that helps
They'll fit but they won't work, they have different circuitry, or basically the 07+ is devoid of a circuit board and you just put bulbs in, whereas the 06 and older has a circuit board that holds the bulbs
Thats right. The 07 and newer have 3 wires and 06 and older have 4 wires. So they will need to be spliced in. So to put the 06 lights you might need the plug and wires to splice them in..
is there an adapter?
The 07 and 08 lights are a little bigger than the 06's are. Before Recon came out with the 07-08 lights, their instructions said to use a marine grade weather stripping around the edges of the lights due to the gap because the 06 and older lights are a tad bit smaller.
Well it probably would not hurt to buy a set of used 06's on ebay for real cheap and try to fit them. If not just buy the one you like and try to wire them in.
